Help Edit Voice Mail speed dial (#1) location?
valorian
Android Expert
Is it possible to edit the first speed dial location that calls your voice mail? I want to add two pauses and then my password. I found the section where you add to the speed dial list but I cannot edit the first location.
You can't edit that, but you can edit the voicemail number on your phone. Go into the phone, press menu, go to call settings, go to voicemail settings then voicemail number then you can put your password in there. You can either use the pause/wait buttons or use commas and semi colons respectively.
Hope this helps :)
