I can edit all of my speed dials execpt the voicemail (1) . It appears to be locked. I want to add a 2 sec pause and then my PW. anybody know how to do this?
Thannks
I found on my phone that setting is grayed out. What i ended up doing was 1. select "Voicemail service" 2. My carrier "ok" the edit number comes up. When you type the number on the screen it does not show but after you select enter, it will appear on the numbe screen. I travel so verizon suggests 2 "P"
