Apps Editable.getText().toString() not working
rishi360
I'm trying to create a String and then append it to a URL. But, for some reason, the toString() method doesn't work. From what I can tell, it just gives me a blank String (there IS text in the EditText).
text = edittext.getText().toString();
Help? :/
Are you seeing any exceptions?
What API Level are you building for?
I just built a quick test Hello World style and the following worked fine:
Code:
EditText editor = (EditText) findViewById(R.id.EditText01);
Toast.makeText(getBaseContext(), editor.getText().toString(), Toast.LENGTH_LONG)
    .show();
I don't believe there are any exceptions. It just returns a blank String, as far as I can tell.
Ummm I'm not exactly sure >_< But it's Android 1.6.
Code:
//use text to make finalTextG have "+"
googleURL += finalTextG;
guri = Uri.parse(googleURL);
Intent gintent = new Intent(Intent.ACTION_VIEW, guri);
startActivity(gintent);
EDIT: Nvm I got it working.
Code:
String text = edittext.getText().toString();
                text.replaceAll(" ", "+");
                googleURL += text;
Try this:
Code:
googleURL += text.replaceAll(" ", "+");
That line of code should take you to your happy place...
