EditText conditional problem
alavro_
So i have a EditText field, which i want to, check if the age is above and under my limits.
if (Integer.parseInt(age.getText().toString()) < 18 && Integer.parseInt(age.getText().toString()) >= 0)
But also, i want to simply check if the field is empty, for what i used.
else if (age.getText().toString().isEmpty())
Unluckly this one is not working, i think it sort of get in to conflict with the first one or something, because i tried with just one condition of both, and it works..
I also tried to store in String variable the method to check isEmpty(), and also in int one, to do the age comparation, but it still not working.
Thanks in advance.
