Apps EditText to string and logic problems
Hey guys...I have some weird things going on with my android app. The first thing is a simple logic problem. I have some thing evaluating to true but it is not being detected correctly...here is my code:
Code:
package com.cutter.giddyup;
import java.util.Map;
import android.R.bool;
import android.app.Activity;
import android.content.Intent;
import android.content.SharedPreferences;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
public class Home extends Activity {
	 public static final String PREFS = "Preferences";
	 private String AUTHENTICATED="";
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        Button Setup = (Button)findViewById(R.id.setup);
        //Check to see if user is authenticated
        if(isAuthenticated()){
            Setup.setOnClickListener(new OnClickListener() {
            	public void onClick(View v) {
            		Intent SetupIntent = new Intent(Home.this,Setup.class);
            		startActivity(SetupIntent);
        else{
    public boolean isAuthenticated(){
        SharedPreferences settings = getSharedPreferences(PREFS, 0);
        if (settings.contains(AUTHENTICATED)) {
        		                        String secret = settings.getString(AUTHENTICATED, "");
        		                        if(!(secret.equals(""))) {
        		                                return true;
        		                        else{
        		                        	return false;
        else{
        	return false;
The problem here is at the line with if (settings.contains(AUTHENTICATED))...it is returning true when I am debugging, but it keeps going to the else{return false} for some reason. I don't get it?
The second problem is when Im trying to store text from an EditText control(ie:edittext value = android.widget.EditText@43bca3d8a). I am trying to store a simple username and password a person enters, but it keeps storing that weird value. When I evalute username1.getText().toString()...it grabs the correct text...but when I retrieve it I get the weird value. here is my code:
Code:
import android.widget.EditText;
import android.widget.TextView;
import android.R.string;
import android.net.http.*;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import java.io.IOException;
import java.util.List;
import java.util.ArrayList;
//apache
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.HttpClient;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.message.BasicNameValuePair;
import org.apache.http.params.HttpParams;
public class Setup extends Activity{
	 private String USER="";
	 private String PASSWORD="";
        setContentView(R.layout.setup);
        EditText username = (EditText)findViewById(R.id.username);
        EditText password = (EditText)findViewById(R.id.password);
        		0);
        String un = settings.getString(USER, "").toString();
        String pw = settings.getString(PASSWORD, "").toString();
        username.setText(un);
        password.setText(pw);
        Button Save = (Button)findViewById(R.id.saveLogin);
        Save.setOnClickListener(new OnClickListener() {
        			postData();
        			//write to prefs if authenticated
        	        EditText username1 = (EditText)findViewById(R.id.username);
        	        EditText password2 = (EditText)findViewById(R.id.password);
        	        AUTHENTICATED="true";
                    		0);
                    		            SharedPreferences.Editor editor = settings.edit();
                    		            editor.putString(AUTHENTICATED, "true");
                    		            editor.putString(USER, username1.getText().toString());
                    		            editor.putString(PASSWORD, password2.getText().toString());
                    		            editor.commit();
        Button Clear = (Button)findViewById(R.id.clearLogin);
        Clear.setOnClickListener(new OnClickListener() {
        			clearData();
    public void postData() {
        // Create a new HttpClient and Post Header
        HttpClient httpclient = new DefaultHttpClient();
        HttpPost httppost = new HttpPost("http://localhost/Android/Login.ashx");
        try {
            // Add your data
            List<NameValuePair> nameValuePairs = new ArrayList<NameValuePair>(2);
            nameValuePairs.add(new BasicNameValuePair("un", username.toString()));
            nameValuePairs.add(new BasicNameValuePair("pw", password.toString()));
            httppost.setEntity(new UrlEncodedFormEntity(nameValuePairs));
            // Execute HTTP Post Request
            HttpResponse response = httpclient.execute(httppost);
        } catch (ClientProtocolException e) {
            // TODO Auto-generated catch block
        } catch (IOException e) {
    public void clearData(){
        username.setText("");
        password.setText("");
any help would be greatly appreciated. Thanks
Try setting your SharedPreferences keys to something besides empty Strings. Like:
Code:
private static final AUTHENTICATED = "authenticated";
private static final USER="user";
private static final PASSWORD="password";
I'm assuming that your SharedPreferences object doesn't like you using empty strings as keys, and using the same key (empty string) for each preference. Dollars to doughnuts that that's your problem.
--Boogs
Code:
--Boogs
That was it!! Thanks so much
