Eduroam connection
CathFr
I haven't been able login to Eduroam on my Android 7 Sony Xperia A1 since I bought it last month, despite all my login details being correct. I recently figured out that by not selecting any security certificate at all [i.e., CA Certificate: Do not validate; Phase 2 authentification: None] I could access Eduroam! However, this seems like a serious security flaw.
I have just been in contact with Sony [for a second time in the last week]. This time, I talked to someone who appeared much more knowledgeable about the Eduroam connection issues. They stated that Sony are aware of this connection and security certificate problem, which is different information from my last contact with Sony and implies that this is an issue with the device itself. The suggested solution was to reset all network data. I will not have access to an Eduroam network for another week to test this solution but I wished to pass on the information.
Has anyone else come across this issue with other Android devices?
Please let let me know what are the security implications of this and whether this is something that should be dealt with in the OS.
Quite frankly it sounds like Eduroam and Sony are blaming each other, you're stuck in the middle, and can't do a lot until they resolve their problems, unless you can find any alternative. I know we don't use Eduroam in China, so don't know anyone here
My settings are CA certificate unspecified, Phase 2 Authentication None. But those are what my institution's IT department said should be used, so they clearly don't have a problem with it.
Frankly Eduroam authentication is a bit of a lottery anyway: if something doesn't work it could be the network you are using or your home institute's authentication server, and good luck to the end user trying to figure it out. Today my Android devices would connect fine but my laptop wouldn't, but right now I'm using the laptop on eduroam with no problems (and without changing anything, which is why I'm sure that wherever the problem was it wasn't my equipment or settings).
