Email saving problem
David Tune
Rank:
Hi,
I'm using Samsung Galaxy 6 and tablets on a MS outlook 364 email. I have 100's of email folders and sub folders. In an older version of android on my galaxy S6 to save an email you could select a folder and then select a folder to drill down on the branch that I wanted. On an android update 3 months ago this was option was replaced by the top branch an then swipe down to the sub, sub, sub folder. There is a very small scroll bar icon that's difficult to capture to scroll down to the right sub folder. The Samsung tablet folder is easier to use use as it's still has the drill down option and a message that appears stating the saved sub folder name.
Who, how do I contact to request either the very small scroll down bar is increase that will make it easier to locate the correct sub folder or return to the drill down icons for sub, sub sub Folders.
I hope I have explained myself and thank Q in advance. Regards
Sorry..didn't get any of what you said, my friend..could you shoot a picture or two?..or is it you are trying to get the older version of the outlook the very same one you used to have?, the 3.6.4v?
Hi
  • Good to save email
  • Then scroll, scroll, scroll
  • As you see most of the folder headings are the same which makes it difficult to select the right one because of the hundred or so folders the file name is hidden out of sight even when turned 90 degrees .
  • There is not large scroll icon (as there is on the right hand side of the screen when scrolling emails
  • Thanks
I feel you now..try this version of outlook..I was playing with it about an hour ago..it seems to have more colors and animations..another option..why don't you use characters in the names of the subfolders and so on..or something different to make them distinctive..you can even paste an emoticon together with the names..
Let us know.
<br>
<br> Let us know.
Well done Xavier!
I'll let you know
Thank Q
