Emish X700 XBMC hardware acceleration
Spawn2
Hi All,
I have the Emish X700 quad core android boc, it came pre-installed with XBMC, i have tried about 4 different versions so far and still have the same problem.
if i try to run a TV show or Movie in any format (via USB hard drive connected to the device, not wireless) it stutters and freezes then reboots the device.
this is mainly with hardware acceleration on, i only have 2 options under this, libstagefright and media something or other.
when i run in software mode i dont get the option to change render mode!
divx works for a little while under software.
please can someone help? although i have ordered a new vidon box to see if that resolves my issues!
Thanks in advance
