Nuno Feliciano
Hi,
I have installed Android Studio in a new laptop, and now I cannot get AVD to work. When I try to run a device, I get a message
immediately after launching the device. I have tried with API 29 and 30. I have installed the following tools
If I try to run the emulator by command line I get:
I think everything is the same as what I had in the other laptop, expect in this one I am using HAXM. But if I unistall HAXM, I cannot launch a device in AVD, and I have to install it again. I don't know if it is related to the issue.
Any ideas?
Thanks, Nuno
Code:
"The emulator process for AVD <AVD-name> was killed"
Code:
C:\Users\Nuno\AppData\Local\Android\Sdk\emulator>emulator.exe -avd Nexus_6_API_30
emulator: Android emulator version 30.6.5.0 (build_id 7324830) (CL:N/A)
handleCpuAcceleration: feature check for hvf
added library vulkan-1.dll
Failed to open /qemu.conf, err: 2
HAX is working and emulator runs in fast virt mode.
emulator: INFO: GrpcServices.cpp:315: Started GRPC server at 127.0.0.1:8554, security: Local
emulator: INFO: EmulatorAdvertisement.cpp:93: Advertising in: C:\Users\Nuno\AppData\Local\Temp\avd\running\pid_11172.ini
Failed to sync vcpu reg
C:\Users\Nuno\AppData\Local\Android\Sdk\emulator\qemu\windows-x86_64\qemu-system-x86_64.exe: error while loading state for instance 0x0 of device 'goldfish_pipe'
deleteSnapshot: for default_boot
VCPU shutdown request
emulator: Saving state on exit with session uptime 25 ms
Any ideas?
Thanks, Nuno
