andrewduerden
If you enable GPS but dont use it, does it drain your battery? I've gotten used to having GPS disabled and manually turning it on when I need it. If GPS only fires up when its needed , is there any downside to having it enabled all the time?
WikipediaWictionaryChambers (UK)Google imagesGoogle defineThe Free DictionaryJoin exampleWordNetGoogleUrban DictionaryAnswers.comrhymezone.comMerriam-Webster<>0
wvcidfjoguarm
wvcidfjoguarm
