Ending second answered call only while first call is active
I have a new S3, SCH-I535 with Android 4.0.4
When I am on a call, if I receive a 2nd call and answer. After I am done with the 2nd call, I tried to end that call keeping the first call open but amazingly it ended both the calls.
After that I've tried to this in different ways. No matter what I do, all the calls are dropped.
Then I've contacted Samsung support and they confirm that, there is no feature that could end single call.
Isn't it the basic feature of a phone?
Does anyone have a solution?
Thanks!!
Thanks!!
instead of ending the call is there no option to switch back to the other call, that should should essentially end the other call
Thanks for the response.
I've already tried that. The problem is, if someone else calls it directly goes to voicemail. I need that second call to be ended, so that if someone else calls I would like to take that call.
What a SAD feature. I have been an iPhone user for 5 years. It was bad in most of the things including signal strength.
Samsung made it worse in the basic phone feature.
