Epad Video Problems
Iblis
I just got an Epad not that long ago and am having trouble adding movie files.
I've used handbrake, dvd decrypter, etc. and the file reads on the Epad properly, except the audio and video play at different speeds.
The audio plays normally while the video lags behind.
Is this just that the Epad can't handle movie-sized mp4? or do i need to change something in the convertion process?
Nope. Plays on my computer just fine. Heck, the file plays fine on my mp3 player (after it converts it that is, but still...)
that's why I thinks it's more of an epad problem...
General
Complete name : C:\*personal info*\TransformerMovie1986.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 608 MiB
Duration : 1h 24mn
Overall bit rate : 1 003 Kbps
Encoded date : UTC 2011-02-05 05:21:18
Tagged date : UTC 2011-02-05 05:51:16
Video
Format : MPEG-4 Visual
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 1h 24mn
Bit rate mode : Variable
Bit rate : 840 Kbps
Maximum bit rate : 8 245 Kbps
Width : 708 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 23.964 fps
Maximum frame rate : 23.988 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.103
Stream size : 509 MiB (84%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 24mn
Bit rate : 160 Kbps
Maximum bit rate : 214 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 97.0 MiB (16%)
Language : English
do you think that's actually the problem?
Also, do you think if I got a program for playing various media files (avi, wmv) that it would work better? or should I say, work at all?
Could be.
Its worth a shot. It only takes a minute to download RockPlayer from the market and try it.
