Error While playing vedios using Rockplayer and Moboplayer
Hi i am using lg gt540 with android 2.3 yesterday i when i play a video the video becomes laggy. Once i have no problem with playing videos..Yesterday it started?why?Is there any App Similar to Mobo Player and Rockplayer.....
Plz give the soloution i have reinstalled the apps but not working..
I HAD USED BOTH SOFTWARE DECODING MODE AND HARDWARE DECODING MODE
I doubt another mediaplayer would do better if those two were laggy.
If these are new videos, then you can analyze them with MediaInfo on PC.
If these videos are the same you used to play OK before, then it is possible that SD card is starting to be problematic. A card format might fix it.
Have you set MoboPlayer to prefer software decode? Or are you playing files that the hardware decoder is incompatible with, like AVI or WMV? For best performance your files should be encoded as h264 MP4 at your native display resolution.
1) Are the videos stored on your SD card or are they streaming from the web?
2) What is the video type (MPG, MP4, WMV, MOV, FLV, etc)?
3) What is the resolution (240p, 640p, 720p, etc)?
It may be that your 600MHz phone just doesn't have the horsepower to decode certain types of video-- especially higher resolution video.
Yes I the Vedios are stored on SD CARD.No they r not streaming frm the web
I USE BOTH FLV AND MOV NUT NO USE
THE RES-640P and 420P
My Phone is overclocked to 806Mhz Is that enough
Depends more on the processor type, not necessarily the speed. Mine can't do even 360p, even at 800Mhz, because it's just a poor old ARMv6 that is fine for applications, but lacks most instructions needed to make software video-decoding fast enough.
