Help EVO VIEW as Phone!
jav0520
I have managed to get outgoing calls on my sprint evo view Using Clubtech's mod from XDA, But i can't seem to get calls when the Tab is on standby. I can only receive calls if I'm on another call. I need a devs help to tweak this to perfection. anyone?
Subscribing to this one.
Would like to know how this works out.
Hi jav0520,
I did the clubtech's mod of S-OFF, root and then changing build.prop adding below two lines
ro.ril.reject.cs.ss.enabled=0 ro.ril.reject.mo.ussd.enabled=0
and modifying ro.phone.function to 1. But in my HTC EVO View 4g, I don't see the phone app. Could you help me what else should I do to see the phone app. I even did the BT mod mentioned in that link. Still no use.
Appreciate your help.
-KP
http://androidforums.com/members/jav0520.html
I can make calls over wifi using Groove IP and my Google Voice number. Not sure why I would want to but wanted to set it up just in case. Didn't try incoming calls but they're supposed to work.
I used the B@@st Mobile flash, and use the 3g to make calls with Groove Ip and Google Voice....data plan for 3g is .50 cents/day. $15.00/ month to use tablet as a phone, and mms device.
Its great. Even better, that if Im around Wifi, and dont need the 3g, Im not paying for something not being used.
