Adding and Removing Home Screen Panels
Your device comes with seven Home screen panels. You can customize the Home screen by removing or adding panels.
Note: The panel in the center position displays when you touch Home.
From a Home screen, pinch the screen from the left and right side to the center to display the editing screen.
Note: Touch and hold on the screen until the Home screen pop-up displays. Under Add to Home screen, touch Page to add a Home screen.
Use these controls to configure panels:
Remove icon: Touch and drag a panel to the Trash Can to remove the panel from the Home screen.
Add icon: Touch to add a new panel, up to a total of seven. This option is available when less than seven panels have been added.
Default Home Page icon: Touch the Home icon at the top of a panel to set it as the default home screen.
To rearrange the order of panels:
Touch and drag a panel to a new location.
To return to the Home screen:
Touch Back Key..
Note
This guide will work on all Samsung Galaxy Tabs; including Samsung Galaxy Tab 4 7.0, Samsung Galaxy Tab 4 8.0 and Samsung Galaxy Tab 4 10.1.
