Okay so I've had this phone for maybe 3 months? For the past couple weeks I've had to hold the volume rocker up and the lock key to turn it on,otherwise it comes up with that screen of the battery symbol that has the loading circle in it,and then it pops up that symbol saying apparently my device is too hot? I've never done anything to harm the device so what is the issue for that? also that's not the main problem. I honestly don't mind having to turn it on like that no biggie,but like 50 percent of the time i do turn it on it won't stop vibrating..and it keeps saying "running media scanner"..... and when the device does actually boot up and successfully it usually happens within the next hour anyways. then I have to take the battery out,wait 5-10 minutes...blah blah just for it to happen again. please help!!!!
edit: also if this helps iv noticed if its on the charger it doesn't do that media scanner thing it..but like 1 mintue after i take it off the charger it does it!
