So I've decided to play around with this Tasker app and boy is there a learning curve!
But I like a challenge like this.
Anyway, quite possibly an easy question to answer for some of you familiar with the app, but do I really need an Exit Task?
For example, a simple time based task.....
I set all my volume levels to a determined level ---the task.
I added a profile to run that task starting at 22:01 to 05:30 every day of the week.
Now, I did not specify an exit task. When that task is completed at 05:30, will it revert my sound levels to where they were before the task was run?
I get conflicting answers when searching the Tasker wiki and video's I've looked at.
Unless I'm misunderstanding what exactly an Exit Task is really for?
and it seems the more tasker can do, the less I would need other apps to perform the same tasks.
