Lê Quốc Việt
Member
Table Partion repartition to increase space on the internal data (partition data set)
Method 1:
You can use Mod Disable to disable the internal SD memory partition (internal), when you install the application, new game, the default will take advantage of the space on the SD card.
It suits for SD Card Class 10 then, to ensure application performance.
Link: http://androidforums.com/threads/disable-internal-sd.921136/
(By author link advertising, you take the trouble to master pages and press the link (wait 5 seconds and skip ads))
Method 2:
Use Partition Table Tool Tool v1.0.1
Photos after repartition:
Link: https://drive.google.com/folderview?id=0B8l7USeq3-gWTVl0ZFZ5MU90aTg&usp=sharing
(Note: download the correct version: L70, L90, L65, f2fs)
Partitioning
- Requirements:
+ Recovery TWRP (I use v2.8.7.0)
+ Backup before implementation
- Support: D325, D325n, D320, D320n (there are someone have been successful), ??
- Implement:
Step 1: Enter TWRP Recovery
Step 2: Tap "Backup" to back up
Step 3: Install> Choose zip file: PartitionTableTool_v1.0.1_L70.zip, Swipe to flash (This doing not install anything, just to run Partition Table Tool only)
Step 4: Partition Table Tool interface will appear as follows:
Select D325 / D325n / D320 and click Next (If the selected item is L90 D415 below)
Step 5: At this point I will use a partition accordingly.
- If we use the selected CM 12.1 maximal (CM12.1), then partition to install the application you will have about 2,6G 1G larger than stock.
- If we use smaller ROM then choose Mod stock, then partition System will be very little, and only 478M.
- If the back set of the stock ROM manufacturer LG is selected 3rd line - Stock, ie partitioning software is only 1.5g.
Then Next
Next just click Next, if such notification, select Yes, because this job will lose all data
The repartition process begins
When the processing to 70%, the phone will automatically restart and enter TWRP automatically. After TWRP started, swipe Allow modified to accept repartition. Then, begin on step 3, mean run the Partition Table Tool and repartition again.
Note, in my phone, when the processing up to 70% and repartition again (mean not 100% complete), but the partition still perfect.
Then, Wipe> Wipe Advanced to destroy data at items: Davik Cache, System, Data, Cache and Internal Storage. Note, do not select sdcard, because that's your memory card, choose the wrong is right bitter lesson.
Followed by Restore Backup or Install new ROM on the new partition.
Good luck !
(My english is bad and i using google trans)
Method 1:
Method 2:
Partitioning
- Requirements:
- Implement:
Then Next
Good luck !
