Help Extended battery conditioning advice.
Ive seen other threads, under different models. Im getting the 3500mAh Ebay battery and would like to learn how to properly condition the battery. Anything from an app or simply just draining it and charging it fully.
I guess whats most important is longevity and digital accuracy. Appreciate any tips or a tutorial?
Corey.
Wiki How tips:
Turn the phone off. This will probably be the most effective and simple way of conserving your battery’s power. Why? This will help conserve energy and also charge your phone. If you don't plan on answering the phone while you're sleeping or after business hours, just turn it off. Do the same if you are in an area with no reception (such as a subway or remote area, since constantly searching for service depletes the battery fairly quickly. Some phones have an automatic power save feature, but it takes about 30 minutes with no service to kick in. By then, much battery power has been used. If you don't need to receive or make calls but are using a smartphone as a PDA, disable the phone functionality (flight mode).
Stop searching for a signal. When you are in an area with poor or no signal, your phone will constantly look for a better connection, and will use up all your power doing so. This is easily understood if you have ever forgotten to turn off your phone on a flight. The best way to ensure longer battery life is to make sure you have a great signal where you use your phone. If you don't have a perfect signal, get a cell phone repeater which will amplify the signal to provide near perfect reception anywhere.
3
Switch the vibrate function off on your phone, using just the ring tone. The vibrate function uses additional battery power. Keep the ring tone volume as low as possible.
4
Turn off your phone's back light. The back light is what makes the phone easier to read in bright light or outside. However, the light also uses battery power. If you can get by without it, your battery will last longer. If you have to use the back light, many phones will let you set the amount of time to leave the back light on. Shorten that amount of time. Usually, one or two seconds will be sufficient. Some phones have an ambient light sensor, which can turn off the back light in bright conditions and enable it in darker ones.
5
Avoid using unnecessary features. If you know it will be a while before your phone’s next charge, don’t use the camera or connect to the Internet. Flash photography can drain your battery especially quickly.
6
Keep calls short. This is obvious, but how many times have you heard someone on their mobile phone say, "I think my battery’s dying," and then continue their conversation for several minutes? Sometimes, the dying battery is just an excuse to get off the phone (and a good one, at that), but if you really need to conserve the battery, limit your talk time.
7
Turn off Bluetooth. It will drain your battery very quickly.
8
Same goes for WIFI, GPS, and infrared capabilities, if your phone has these features built in. Keep them off except when you need them to save power.
9
Use GSM rather than 3G - Using your phone in 3G / Dual Mode will drain the battery quicker than if you just use GSM mode - have a look at your phones spec and you'll see it will quote two different battery life times - normally 50% more for pure GSM use.
10
With a smartphone, avoid using moving or animated pictures or videos for your background. Animated backgrounds will drain the battery faster.
<LI class="steps_li final_li">11
Use a black background whenever possible. AMOLED screens use a lot less power displaying black instead of white [1]. When web browsing use sites like bGoog.com [1] that display a black Google background instead of white.
Prolong the Life of Your Battery
  1. 1
    Initialize a new battery. New batteries should be fully charged before their first use to obtain maximum capacity. Nickel-based batteries should be charged for 16 hours initially and run through 2-4 full charge/full discharge cycles, while lithium ion batteries should be charged for about 5-6 hours. Ignore the phone telling you that the battery is full&#8212;this is normal but is not accurate if the battery is not initialized. #DO NOT fully discharge a lithium-ion battery! Unlike Ni-Cd batteries, lithium-ion batteries' life is shortened every time you fully discharge them. Instead, charge them when the battery meter shows one bar left. Lithium-ion batteries, like most rechargeable batteries, have a set number of charges in them.[2]
  2. 2
    Keep the battery cool. Your battery will last longest if used near room temperature, and nothing wears on a battery like extended exposure to high temperatures. While you can&#8217;t control the weather, you can avoid leaving your phone in a hot car or in direct sunlight, and you don&#8217;t have to carry your phone in your pocket, where your body heat will raise its temperature. In addition, check the battery while it&#8217;s charging. If it seems excessively hot, your charger may be malfunctioning.
  3. 3
    Charge your battery correctly, in accordance with its type. Most newer cell phones have lithium-ion batteries, while older ones generally have nickel-based batteries. Read the label on the back of the battery or in the technical specifications in the manual to determine which yours is.
    • Nickel-based batteries (either NiCd or NiMH) DO NOT generally suffer from a misunderstood phenomenon known as the "memory effect." As described in Wikipedia and many expert sources,[3] the term "memory effect" has been widely mythologized to describe any and all deterioration of NiCd (and other battery chemistries), in many cases misleading consumers into further shortening the lives of the batteries through over-discharging to "recondition" them.[4]
    • [This section formerly read: If you charge the battery partially enough times, eventually the battery "forgets" that it can charge fully. A nickel-based battery suffering from memory effect can be reconditioned, which requires the battery to be completely discharged, then completely recharged (sometimes several times). The appropriate length of time between reconditionings varies. A good rule to follow for nickel-battery cell-phones is to discharge them completely once every two to three weeks, and only when you have a charger available. [5] ]
    • Lithium ion batteries can be preserved by careful charging and avoiding storing them at full charge.[6] They do not require "reconditioning."
    • Regardless of the battery type, use only a charger rated for your battery, and discontinue use of a charger that causes the battery to heat up excessively.
  4. 4
    Store batteries properly. If your battery will be out of use for a while, disconnect it from the phone and store it in a cool and dry but not freezing place (an airtight container in a refrigerator, but not a freezer). Don't keep it with metal objects that might move around and short-circuit the terminals. Lithium ion batteries are not rated to operate at refrigerated temperatures, so let the battery sit outside the refrigerator for at least an hour before using it again. Lithium ion batteries oxidize least when they are stored at 40% charge. Never store a lithium battery at low voltage. Recharge batteries after storage.
  5. 5
    Clean the battery contacts on the battery and on the phone. Over time, contacts may accumulate dirt which reduce the efficiency of energy transfer. Clean them with a cotton swab and rubbing or isopropyl alcohol. If the contacts are two different metals, such as gold and tin, accelerated corrosion known as "galvanic or bi-metallic" occurs. Cutting the corrosion from the contacts often requires solvents, such as acetone or nail polish remover. Be careful: these solvent dissolve plastic, so use a Q-Tip to avoid damaging the battery housing or the phone.
