Hi Frisco
It did come with the wider back cover,it is obviously a little bit fatter but nothing too bad,the benefit of extra battery life outweighs the negative.
I dont wear it on a belt or put it in a holster thingy,i use mine 'bareback'
not sure if it fits your phone though.
3 days on and im still like dog with two d...s.
Tomo
I probably have the same one and battery life is simply not an issue any more even if you leave stuff on like wifi. The best investment you can make for your phone and you can now use the phone the way it was meant to be used.
I would recommend anyone to invest in a bigger battery and stop the moaning about battery life as there is a cheap solution.
