If you're like me and wanted the option to download your Spotify tracks to your external SD, here's a workaround.
Now you're good to go! :smokingsomb:
- Force close and clear out all Spotify data then uninstall.
- Download and Install https://www.dropbox.com/s/br5q7kg8qc9xqrf/SpotifyAndroid.apk - this is an older version released in April
- At the login screen, press the menu button and select SD card
- Under path, type in /mnt/extSdCard/
- Login with your Facebook account
- Exit and download the update in the Play Store
