External storage problem
andybrody
Hi I have a Sumvision Android X2 enclosure and very happy with it, apart from one thing that I think is a general Android problem, if I move/change any of the USB storage devices (including internal USB HDD) the
storage names will change e.g. from sdc1 to sda1 and so on. This causes a lot of problem with the Samba (SambaDroid)server I'm using.
Here is the question:-
Does any one now of a way via the Android System or by an App to permanently (as in windows) naming the external storage.
I hope this is clear and that someone can help. Spec of unit is below.
Thanks for reading.
Andy :)
CPU ARM A9 DUAL CORE, 1500MHz, 3D engine
RAM 1GB
STORAGE 4GB FLASH MEMORY(expandable using SD/SDHC card)
INPUT 4x USB port, SDHC slot
LAN RJ45 and Wi-Fi 802.11n 150Mbps
HDD up to SATA 2 TB
ANDROID 4.1
