Hmmmmm-
Well, thanks for the reply
Speed Daemon
I appreciate the effort
I am getting at wanting to bypass the incredible interface, to the directory that houses the saved voice mail files and transferring that .wav as you suggested to my desktop
In the order of your reply if you want to explain
-- use a product that e-mails a sound file (typically a WAV file)
My provider is absolutely useless
Verizon is good for many things, but customer service staff understanding how the incredible works is not one of them
-- If you have control of the voice mail server, you can probably find and save the sound file for that voice mail in the native file format of the voice mail system. But if you have that sort of access, I'd think that you'd already know how the system works
I access the cellphone company's voice mail user interface I can only listen, delete or keep messages etc Nothing else is available through Verizon that I am aware of
Lastly, This, though 'hella impressive may as well be latin to me
-- I used a POTS phone with a headset jack to call the cellphone company's voice mail access number, and recorded the analog output from the headset jack to a PC, using a pro audio ADC with an audio patch cable between the phone and the ADC
The skills and equipment this took is beyond my paygrade
But, if I can as mentioned, get behind the user interface and grab the .wav file and pull it onto my desktop that'd be ideal
I have instructions for 'jailbreaking' the GUI, but they are step by step for a PC and I am on a MAC (how many times in my life has this happened, Eyie Carumba) thx your doing the lord's work just replying -cheers
