Facebook 130.0.0.45.70 issue
pm5544
Anyone having an issue with the latest Facebook app logging in and flashing screen, deleting cache etc helps for a short period but issue returns.
My solution is that you search for version 128 and install,  this should resolve this issue until Facebook fix it.
To do this you will require to allow unknown sources to install, once this is done install the apk and remember to go back into security and disallow unknown sources.
Reason I placed this here is because this affects this phone on Android Lollipop 5.1.1 which this phone currently uses.
I've encountered issues with Facebook, they are horrible with updates that break things almost weekly.
Apkmirror will have Facebook older releases. Find one and install that, and turn off auto updates from your play store settings
Hi, that's exactly what I use just now, currently using version 128, the annoying thing is that they keep asking me to update to a newer version, they aren't listing to people either unfortunately.
And that's Facebook for you...
If you want, delete the app and just login using a browser instead
<br> If you want, delete the app and just login using a browser instead
Yeah, done that too, however you lose some functionality by just using the browser version. They've obviously dropped support for the Android Lollipop 5.1.1 version but just don't want to admit it.
Seemingly there is another issue with the current version of Facebook for Android which is not being able to edit your very own comments, the version with this issue is 153.0.0.54.88 the following older version without this bug is 149.0.0.40.71
With ref to above is Android Lollipop 5.1.1.
