Have the Razr Maxx less than a week. Finally rooted & started removing apps, changing settings, tried to get wireless tether & barnacle to work (unsuccessful). Apparently I disabled/removed/installed the wrong thing along the way, & now I lost all data connectivity: -4G, -3G, -1x = no internet = no email. Went over all settings, soft reset, no luck. Called Verizon, unable to help. I already backed up apps + data on Titanium, and unable to use Rom Manager for anything, Razr not supported.
I'm about to do a factory reset, but need to know:
1) do I have to un-root first?
2) do I remove SIM card b4 reset?
3) is reactivation required after reset?
4) is there a specific sequence of actions to do this reset?
