Help factory reset and reactivation help
ok so i have the moto G 3G first gen phone for verizon and i want to do a factory reset but i already have the phone set up on a verizon prepaid plan so if i do the factory reset how do i get the phone back on my prepaid plan with out having to activate it on a new plan
When you reset your phone the Verizon network should still recognize it and reactivate it.
Also, I moved this to the Verizon forum since it's a question about Verizon service :)
I agree, the phone's IMEI number is already registered on the VZW network.
Therefore, a full reset will be exactly like as if you were turning on the phone for the 1st time after you prepaid your monies.
If you need a reset to clear out problems, go for it.
____________________________________
2 ea. Verizon Galaxy S5, 4.4.4 forever!, ART
MyPhoneExplorer lets you access a broken phone while locked
Nova Prime, Textra, Blue Mail, Qi wireless equipped
MacroDroid can help extend battery life
MacroDroid senses Screen off, turns Wifi & Data OFF
MacroDroid senses Screen UnLock, turns Data ON
