factory reset error, please help me
First things first: hi and thanks for your help^^
Like the heading says I'm experiencing quite the problems with the factory reset I can't fix myself.
I had to do the reset due to the commonly known ''unfortunately play sore has stopped working error'', because I'd tried everything else and nothing worked so the last thing I could do was the reset, but now I'm stuck at the checking for updates screen for hours.
Restarting the phone won't work.
Hello!
How did you factory reset?
From within the OS or recovery?
Perhaps try booting back into recovery, factory reset again from there and reboot?
