So my fascinate has developed an issue with there being static, not constant but about every 2 seconds a quick little static blurt if you will while listening to audio. Now the funny thing is when the screen either times out or I shut it off it stops, then its fine, so it only does it when the screen is on. Still annoying. Anybody have any ideas?
Thanks in advance.
Thanks in advance.
