Fast Charging Problem - Car Chargers
mormandy3
I am unable to fast charge my new Note 9 on any car charger or cable, but fast charging is no problem with a cable plugged into the wall charger. I can slow charge on any of those car chargers, but that is lucky to even keep up with battery drain. I have tried several different Samsung car rapid chargers, and just picked up the highly rated Anker dual port fast charge 3.0 charger today, same issue, no fast charging. Of course fast cable charging is enabled in the menu, I've tried restarts, multiple OEM Samsung fast charge cables, etc.
I called Samsung, and after struggling with the horribly thick East Indian accent of the tech support person, I was told to take the phone to an authorized center (a half an hour from me), and that the phone may need to go back for work. I'm probably going to return the phone after work as I'm not going to be an unpaid beta tester for a $1,000 phone, but I thought I would see if anyone has had a similar experience or any input first.
there are lemons out there. its a mass produced product. anything mass produced will have lemons.
that said, ive 3 note 9s and i have zero issues with charging fast.
you should return the phone.
Good comments, and agreed, time to return. I even tried safe mode and reset it and found the behavior even more strange than I first thought:
Before resetting, tried safe mode. Result: said it was fast charging, but the time remaining was consistent with regular charge.
Full reset. Result: would not say fast charging with cable fast charge turned on, time remaining consistent with standard charge. **Oddly the option for wireless charging disappeared, no longer in the menu now! Turned phone off completely and it said fast charging, but time remaining was consistent with regular charge.
Went back inside, hooked up to wall charger, and verified what I had suspected with time remaining numbers. Fast charge worked correctly with the option turned on, reverted to standard charge with the option turned off. Time remaining was correct based on the option being turned on, or off (significantly shorter time remaining with option on as you would expect).
Back to Verizon it goes, just wanted to share for the record / those who may experience similar issues. Thanks again.
Did you try charging the phone with the USB-C flipped in other side?
I knows it might sound stupid but my HTC Bolt only fast charges on my car charger when I use the "correct" way, even if the port is reversible.
just to make sure those chargers are QC2.0 ? if they are other/non name brand chargers they may not be able to fast charge due to them just not being compatible...
just worth pointing out.
Yes, I tried three chargers. Two OEM Samsung QC units (one dual port, one single port) that were used for my S8+ without issue, and a brand new Anker A2228H11 49 watt dual port QC 3.0 unit that I just picked up from Best Buy. None worked.
Now an interesting update....
I dug out my old S7 QC car charger and it works!! It's OEM samsung with the rapid charge logo, off-white colored, single port. Even though this makes no sense, and is a bit frustrating, my needs are met for the moment and I 'll keep the phone and curse my way through Bixby annoyances until Samsung (hopefully) adds a toggle for it as they did with past devices. I'll attach the link for the S7 charger that ended up working below:
https://www.walmart.com/ip/OEM-Orig...FoUTkXXk8MD_mVblXMM41zp1tK9ptIoxoCpZEQAvD_BwE
