chetank628
I like to share a gps config file which will help for a faster gps fixing on our device
1) u require a root acess for this
2)there is gps config file file in system>etc>gps.conf
3)replace this fie with this one https://www.dropbox.com/s/iq29lck6mz5woe1/gps.conf
4)reboot ur sysytem and clear the previous agps from any gps tool from play store
5)this file settings helped me for a faster fix within few seconds on my device
(so this may also help u)
6)hit thanks if i helped u
basically i suggest u to use baseband v2013 or v910 for better result
the fixing may differ from place to place and weather condition mine gps got fixed with in second that to in heavy cloudy conditons and that to raining
basicaslly this file have some nttp server setting and port which helps in faster fixing of gps then our default servers:deal:
