Hi Guys, newbie here.
I'm heavily considering upgrading to the S5, but I have a question about the scanner.
Most reviews I've read claim that the scanner is half-baked and doesn't always work, plus is awkward to use properly with one hand.
However, I've also read that if you make the effort to scan your finger in at a variety of speeds and angles when you initially set the scanner up that it will work quite properly and that it will then recognize at any angle that you scanned in.
Can anyone tell me which of these two views is more correct/ point me to somewhere where I can find a definitive answer?
Your thoughts are welcome
Slab.
Slab.
