Help finicky 3G signal
ram100987
Member
I don't know if this is a device or network issue so not sure if this belongs in the G1 threards or T-mo but it seems that the G1 doesn't stay in 3G very well here in dallas county. Just being under the shelter of a small garage will usually lead to 1 bar of 3G if at all, I may only get Edge... this is a bit of an annoyance since many apps depend on 3G. Any one else noticed this? Maybe T-mo is still fine tuning it since they just let it roll out...
By the way, I'm only a yar or two inside a garage and I'm getting 1 bar of 3G and it will drop to Edge every now and then
I am having the same problem, It is constantly on EDGE and not 3G. I am hoping it is because it's just getting rolled out. On the plus side though, EDGE seems to be much faster on the G1 then it did on my Wing.
