ROMs [FIRMWARE][DOWNLOAD] Samsung Galaxy Alpha AT&T (SM-G850A) KitKat & Lollipop Firmware
KingOfTheNet
Its kinda weird that AF doesn't have a forum for the Galaxy Alpha, so I'll just post this here.
NOTE: I NO LONGER SUPPORT THIS DEVICE, SO I MAY BE LIMITED ON THE QUESTIONS I CAN ANSWER REGARDING IT.
Here you can download the official KitKat and Lollipop firmware for the SM-G850A.
Edit: As of right now, the SM-G850A can no longer be rooted.
Download Links:
KitKat 4 File Firmware Download (G850AUCU1ANH8): https://mega.nz/#!q4YBEYya!vvBRgCaq7...11KtiMIzX29gns
KitKat Combo Firmware Download (G850AUCU1ANH8): https://mega.nz/#!6kgGSDpa!JhjNMpsKw...e8WBqNcxB2afJE
Lollipop 4 File Firmware Download (G850AUCU1BOC6): https://mega.nz/#!6swkzbhb!eNhUkZqvV...vEyYaZ-u3OSyrc
Lollipop Combo Firmware Download (G850AUCU1BOC6): https://mega.nz/#!fgZ0iTxJ!Pwh6Laa1E...nMgRWTD1x1JZW4
Odin v3.12 Download: https://mega.nz/#!KsZiHKTb!aEHdQgO7J...ieJ6qTbVKce8Zk
If the links go down or won't work for some reason, please let me know.
Developers Tip: If you want to flash firmware without wiping your data, make sure there is no pit file selected under the PIT tab in Odin, then extract and remove cache.img.ext4 then repack as a .tar file. Applies to both combo and 4 file firmware packages. In 4 file packages, cache.img.ext4 is in the CSC file. However, in some cases this may put your device in a bootloop.
Cheers! :D
