First post....
I've been using Android for a while, this is my first post here tho! Looks like a great place to be an Android fan
For my first question, and I'm not sure if this is the right place. Is there some way... an app or setting to set my device to either Wifi or 4G (or 3G) and have it stay there until I tell it otherwise? When I'm at home if my wireless network hiccups.... which it does....... my Android wants to jump over to 4G and sit there using up bandwidth which if I don't notice it overnight or the like can be alot. I've not seen the problem the other direction with it auto sensing and switching from 4G to wireless but I'd like to standardize all this so I can setup some scripting in Tasker.
So in summary, if Wifi goes away is there a way to tell my device "just sit there, don't do anything, it'll be back"?
Thanks
You mean something like this?:
from the home Screen:
hit Menu key>Settings>wireless & networks>Wifi settings> in this screen hit the Menu key> click advanced>Wifi Sleep policy, and select Never
That may be EXACTLY it! Mine was already set to "Never" but I'm going to try setting it to something else, then back in case it just needs to have it's monkey tree shaken. Thanks.
Even if you set wifi to never sleep if you have had weak or lose your wifi signal the phone will automatically switch to your mobile network, unless you turn mobile data off and then just turn it on when needed
Menu-settings - wireless & networks - uncheck mobile network
Oh and to make turning it on and off simpler. I have an app I use called Widgetsoid. Long press on your screen to add a widget then choose the size you want to make for Widgetsoid, for the mobile data toggle I did a 1x1 switcher then the customize menu comes up and you choose what function you want to use it for and you can theme it (change color etc) then under the profile setting you can save it (make up a name for it) next is to apply it (pop up window I always select no)
Like 2manyphones said, you could use tasker to turn mobile data off when wifi gets turned on, and turn mobile data on when wifi gets turned off.
