First time root, encountering bootloop, help please!
Hello all,
This is my first post, did my best to try and find the right forum for it.
I'm trying to root my P3AXL and am encountering a bootloop issue after flashing Magisk. Reinstalling Magisk does nothing, and the phone will not properly flash permanent TWRP either. I'm having to manually load the image file from command prompt to interrupt the boot loop. At this point I don't even know what to do, and can't load into android at all. Any help would be appreciated.
Hi, good day to you, could you please send the link for my Google pixel phone firmware, because i need to Root it due to forget my password?
That solution is in YouTube..I can't broadcast it in here, though..you just have to dig deeper..it won't be easy but it's there. I got it from there and works charming.
