Trofim
Fit In The Wall
Your task is to clear the figure of extra cubes, in order that-be to get into the right hole without hitting the wall with it, but do not forget that if you remove too many will not be able to earn coins.
Try your best, and let's see how you can go through the walls!
HOW TO PLAY
◉ Remove cube touch, something to get in a hole
◉ Collect coins
Download : https://play.google.com/store/apps/details?id=com.TastyGames.FItInTheWall
Scrennshots:
HOW TO PLAY
◉ Collect coins
Scrennshots:
