fix bootloop in android
Hi,
i was having a small problem about boot loop in my phone.
I am expecting for perfect solutions for this mistake, i have deleted all the default fonts accidentally and replace with my very own fonts, stupidly without thinking of a single precaution. Now i'm stuck in boot-loop forever searching for fonts download replacement, or any program that fixes phone errors through pc?, or forum threads that talks about similar to this problem, but no forums yet have a discussion like this. Now, can you help me?
Thank you in advance.
hi
im using myphone rio craze android 4.4.2 kitkat and i dont know what exactly the carrier name.
i am in a boot-loop right now, what am i going to do.?!
please reply.
Can you open the phone without boot loop? In my case I can
The solution to stop that is to drain the batt. And start it up again... Go safe mode , and try to download fonts .. or factory reset in Settings>backup and reset>reset phone:erases all data on the device ps. This process will erase all your files and apps but will correct and install fonts ,so back it up
But, If you can't, that means your phone is bricked .--. Because the cause of the problem is mannualy made, the warranty may be void after that....
I recommend you search in Google for the solution for escaping that boot loop
This might help you
http://www.redmondpie.com/how-to-fix-or-recover-android-boot-loop-on-stock-and-rooted-device/
And this... http://www.androidcribs.com/2014/10/stuck-on-bootloop-wo-backup-on-cwm.html
