Hello, and welcome to Android Forums!
You will want to remove your sd card and connect it to a pc. Backup any files you have on the SD card you want to keep, then format the sd card to FAT32. You can then replace any files you wanted on there, and put it back in your phone and it should work.
If you have any further questions, I suggest signing up here as a member so you can participate in real time with the other members here, and you will also be able to respond in-line in threads.
Thanks for stopping by, and good luck!
