Help fixed Settings
tursti
Is there a way to fix the Settings on my Nokia 5 with Android 8.1.0?
Sometimes my phone simply turn on Do not disturb, sometimes it turns down Wi-Fi, sometimes turns down Brightness level to the minimum, sometimes turns on Airplane mode, and all of this without me. I do not need Airplane mode, I do not need Do not disturb, and all of this disturbs me all the time because I do not know that the phone turned on Do not disturb, and people can not call me at all.
Those settings sound like the default list of icons in the quick settings panel (swipe down from the top). I would guess that the way you carry or hold your phone is accidentally opening quick settings and then you inadvertently turn one of those options on or off. I'm not sure about Nokia phones but on most others its pretty easy to customize the quick settings panel. Tou could even remove those icons to prevent accidentally touching them.
