Starchild72
It seems to have disappeared from the market. Any know anything about this? as i'm trying to get this app!
I found and successfully installed this on my Archos 101 Tablet from Download free Adobe Flash Player app for Android at Freeware Lovers.
Here's how:
1. Download the .apk file to my PC
2. Mounted my Archos 101 to my PC using the USB cable.
3. Used Windows Explorer and created a new folder called "Downloads" on my tablet file system.
4. Copied the .apk file to the new folder on my tablet.
5. Unmounted and disconnected my tabled from my PC.
6. Used the "Files" application that was pre-installed and opened the new "Downloads" folder, then tapped the filename to launch the install and wah-hoo! I now have Flash support!
From this same website, you can get a number of applications including a nice Google-Developed YouTube app similar to what's on the iPhone, etc..
Oh, and I'm running Android 2.2.1 with the latest firmware (can't find the version).
Cheers!
Jeff
