All android devices have some form of built in flash memory... (as do ios devices)
... is there a particular reason you're asking?
If you're actually encountering a problem than yes, but generally anti-virus utilities are just using up system resources that should be used for things you actually want to do.Does Android need anti virus ever?
How do you block ads in this forum?
Download completed,
Yep,Do you have the option to allow installation of apps from "unknown sources" (i.e. outside the Play Store) enabled?
