I am considering purchasing a Samsang Note Tablet with Android OS. What is the best way to view files created with Adobe Flash Player such as lecture videos?
If it does not come with flash player installed and you cannot find an alternative, you can 'side load' flash player. What that entails is allowing apps from 'unknown sources' and then finding the .apk file and using a file browser to install it.
