flash?
selahfalk
Hi guys!
I got my Droid phone last night and am totally new to Andriod. Whatismyflash.com says I don't have anything installed for flash. I went to megaupdater and d/l'ed a .apk file to install flash 10.1. However, it says it can't parse the package. Tried it twice, same result. What are your suggestions? Am I on the right track to get flash working?
Thanks!!!
Hi guys!
Thanks!!!
If you talking about the MOTO Droid, with 2.1, it doesn't have official Flash support. But you can install 2.2 which does have Flash 10 support.
Sent from an HTC Eris
I am in the same situation. Where can I do this?
Thank you.
I couldn't tell you to save my life. I've got a Droid Eris so I can't do it. I know Droid users can though. You might want to try the Motorola Droid forums.
It shouldn't be long now. It takes Android 2.2 to run on, which Google is still hammering out the bugs on, as well as Adobe is on their third beta of flash. I'm hoping those two things finish at around the same time.
