Accessories Flip Wallet Samsung S6 Egde
I bought a flip cover for my phone, but I think it is very annoying how it turns the screen on and off when it closes and opens, because it closes so easily. Can this feature be turned off on my phone/ is there an app to disable it/ do I have to buy another cover? Thanks
Try using a week magnet (rubberized refrigerator) to locate the magnet built into the flip cover. Tape a small piece of aluminum foil over that location. That should dissipate the magnetic signal enough so that it doesn't trigger the sensor on the S6 edge.
That doesn't sound very plausible, but I'll give it a shot I guess.
