FM Radio/Navigation conflict
iamgigglz
Hey all
I ride a motorbike and use my Sensation (2.3.4) for radio and navigation via normal plug-in headphones.
I have an issue where, if I'm listening to the FM radio and have Google navigation running at the same time, the radio mutes for the navigation instructions, but it seems to mute the navigation instructions as well.
All I get is a few seconds of silence when the navigation wants to say something.
The problem is not affected/solved by which order the apps are started, or by what is currently showing on the screen. No other apps/services are running that would affect sound.
FM Radio ver. 2.0.2116382645.79358
Maps ver. 5.12.0
TTS service ver. 2.3.4
Any help/suggestions? Thanks
