I keep a fairly close eye on my battery level and usage and have been able to deduce a few things which, although common knowledge for most, might help a few people so just thought i'd spell them out here:
I am using R2BA020 firmware and currently am on 70% battery life, 21 Hours, 56 Minutes since last unplugged. I use my phone frequently for texting as well as yesterday browsing the internet for a while and calling and taking a few pictures.
For anyone who is still seeing poor battery performance:
There are reports of the latest update of Juice Defender not working properly, I have not updated so do not know. If you are finding this to be the case, use this advice below, as I can confirm this is a major battery killer!
As said below:
Just a few things I have read, and noticed. Hope this helps someone![Smile :) :)](/styles/smilies/google/smilie.png)
- First and foremost, I would recommend debranding and updating your firmware if you can't already get it. Please remember this may void your warranty. If you want to debrand your phone, head over to: Debrand your Xperia X10 [Tutorial] | Xperia X10 Blog
- Make sure you know what firmware you need (x10i/x10a) this is VERY important.
- Secondly, that popular App, JuiceDefender, I only use the free version but it's absolutely fantastic. Don't try and fiddle with it, just let it setup and do its own thing. (See Note 1 at bottom of post)
- Task Killers: Although there's no need to use them religiously, I keep the 'Advanced Task Killer' widget on my desktop and every now and then just tap it to kill any tasks straight away - you can add apps like juice defender to the ignore list
- --Never use the home button if you are trying to exit an app. This leaves it running!
- Screen Brightness: Leave it to adjust automatically. I used to leave it on full brightness because I love my screen
. It's still perfectly usable and bright if you leave it to adjust itself, and this will save you a significant amount of power.
- Lastly, for anyone who has recently got this phone, be patient. It does take a while for the battery to reach its full potential. Many people say 3-4 days. I have had this phone for 2-3 weeks and would say only in the last few days has it really started to impress me. It's a myth that you need to discharge the battery completely, this was true of older batteries, but with the battery in the X10, charge it at any opportunity. You will soon notice that you can go for far more than a day without charging.
As said below:
Juice Defender has never worked on my X10. Only 2 things have, other than the obvious of keeping Wifi to a minimum and keeping GPS off;
1) Turn off the "location determined by Network" option. I knew location by GPS would kill the battery in minutes, but never thought this apparently simpler option would.
2) Turn off "Background Data".
With that I can now at least get a day out of my phone. If either of those options are on, its much less than a day.
