Force music over AUX cable and Voice Calls over bluetooth
jeepalex
I have found the quality of streaming music from my Motorola Droid 2 to be far less than desirable. However I still want to make and receive phone calls from the bluetooth in my car while traveling. Ideally I'd like to be able to anwser and make phone calls from the bluetooth in my car and stream music out the aux port so I have the best quality. Is there a way to force the droid 2 that when I connect the bluetooth to not send the music over bluetooth to my car stero? Perhaps a 3rd party app?
Thanks
i have the samsung intercetp on sprint and as of the 2.2 update if the bt is paired and i awnser with the bt then it goes to the bt but if i awnder from the screen or my aux cable with mic got at radioshack for around 20 bucks
with the 4square discount
it seems to be related to what features you set under bluetooth as far as wether the bt has a2dp enabled or not
at least how its working for me at the moment
This didn't fix the problem. The check box appear to actually do nothing. i've tried reseting the phone, the uconnect radio and re-pairing and enabling and disabling and it still doesn't work, looks like a bug in android if you ask me.
