hi
got an HTC M8 with an SD card, and when i started getting the storage is low messages, looked into using the SD as internal storage.
i formatted it as internal and all was well for a while. now im getting the messages back again and they wont go. if i go into the storage section, it says .......17.9Gb of 45.2Gb used, then underneath phone storage is 15.74 of 16Gb used, SD card is 2.17 of 29Gb used, so it seems they are still separate.
however, if i tap the SD card, then the 3 dots for options, it gives me the option of 'format as portable', so it obviously is still set as internal.
if this is the case, why is it still saying low storage, and how do i solve this problem? theres loads of room left on the card, id like to use it.
thanks a lot
thanks a lot
