Forward Calls when my phone is on airplane mode
Hi,
How can I forward calls to another number rather than my voicemail when my phone is on airplane mode? I can't see it in my settings. Am I missing something, or do I need to download an app to do this?
Dan
Open your phone app and go into its settings. I don't have a Samsung so don't know how they will arrange these things, but Android phone apps should have Call Forwarding settings, probably inside "Call Settings". There's no "when in airplane mode" setting but you should be able to set it to forward to whatever numbers you like when busy, when unanswered or when unavailable (the last is what airplane mode will do), or at all times (if you use that don't forget you set it - I did once!).
Call forwarding is of course controlled by your network rather than your phone, so these settings are an interface to your phone's systems. This means that they may differ depending on what your network offers (these menus load slowly, I expect because it interacts with your network when loading them).
So yes, within call settings there is an option to change the call forwarding when unreachable, currently set to voice mailbox. However when I try to change it to my desk phone I get the following error:
"Something went wrong. Check your SIM card or network connection and try again "
Hmm, on the rare occasions I've used it it worked for me. But that's a different phone and a different network. It might be worth checking with your service provider (or, depending on who you get, it might not).
