Fragment for menu manage on android studio
julianov
Hello all.Im new on this and I having problem with android menu due to I cant make the app swap to the fragment layout. I follow a tutorial and it works for the guy but here Im having problem. It must be a little mistake but I cant see it by myselft.
This is the MainActivity java code, you can see at the bottom the fragmentManager and how its manage
Java:
public class MainActivity extends AppCompatActivity
        implements NavigationView.OnNavigationItemSelectedListener{
    @Override
        setContentView(R.layout.activity_main);
        Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
        setSupportActionBar(toolbar);
        FloatingActionButton fab = (FloatingActionButton) findViewById(R.id.fab);
        fab.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View view) {
                Snackbar.make(view, "Replace with your own action", Snackbar.LENGTH_LONG)
                        .setAction("Action", null).show();
        DrawerLayout drawer = (DrawerLayout) findViewById(R.id.drawer_layout);
        ActionBarDrawerToggle toggle = new ActionBarDrawerToggle(
                this, drawer, toolbar, R.string.navigation_drawer_open, R.string.navigation_drawer_close);
        drawer.addDrawerListener(toggle);
        toggle.syncState();
        NavigationView navigationView = (NavigationView) findViewById(R.id.nav_view);
        navigationView.setNavigationItemSelectedListener(this);
    @Override
    public void onBackPressed() {
        if (drawer.isDrawerOpen(GravityCompat.START)) {
            drawer.closeDrawer(GravityCompat.START);
        } else {
            super.onBackPressed();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
    @SuppressWarnings("StatementWithEmptyBody")
    @Override
    public boolean onNavigationItemSelected(MenuItem item) {
        // Handle navigation view item clicks here.
        FragmentManager fragmentManager = getSupportFragmentManager();
        if (id == R.id.nav_camera) {
        fragmentManager.beginTransaction().replace(R.id.fragment1, new fragment1()).commit();
         } else if (id == R.id.nav_gallery) {
        } else if (id == R.id.nav_slideshow) {
        } else if (id == R.id.nav_manage) {
        } else if (id == R.id.nav_share) {
        } else if (id == R.id.nav_send) {
        return true;
this is the fragment xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:id="@+id/fragment1"
    android:layout_height="match_parent"
    tools:context="fragment1">
    <!-- TODO: Update blank fragment layout -->
    <TextView
        android:text="Hello world from fragment" />
</RelativeLayout>
Could you please help me?
thanks in advance
